Internal error in RIPng. If it is temporary memory outage it should recover, otherwise, there is not enough memory in the system.
Disable and enable ripng. If problem persists, reconfigure the system to reduce memory consumption or reboot system
Critical
Failed to alloc memory for %num0% size.
| Name | Type |
| num0 | uInt32 |
